I experience with the problem to get always an uninstall before install... always!!!!!
Is there an easy way to make the changes in the script? in the prereqs section?
What do I have to modify?
It would be great to get an little sample script or description...
regards
allways uninstall?
Re: allways uninstall?
you could move the uninstall section in order to be executed later in your main script.
For example, This can be easly experimented with a new project from scratch, postponing the uninstall process just after the "start Installation" dialog.
( ... the uninstall of the previous installed package must be completed before to start the effective package installation).
