Get Folder location gives wrong folders with Installawre 15
AlejandroNehring
Post by AlejandroNehring »
With Installaware 15
Get Folder Location "CD Burning Directory" gives user-desktop directory
Get Folder Location "Profiles Directory" gives program directory
similar with many other "Get Folder Location" calls. I did not try all of them.
Opening old setups created with older version and creating a new setup with wizard shows same results.
Is this a Bug in Installaware 15 ?
Re: Get Folder location gives wrong folders with Installawre
we are informed of it and we are really sorry for what happened.
An update to fix this behaviour should be available soon.
just to inform you that the issue you reported has been fixed with our new InstallAware update 15.32.
mikKummerfeld
Post by mikKummerfeld »
Do you have a changelog for that version? It is not visible in your blog...just the january version :(
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
the change log indicates all the fixes released and included with the most recent IA version. (Currently IA ver. 15.50)
You should refer to the IA version reported with the blog post and not to its date.
