its me again. Sorry for that asking all the time^^
Where can i translate the Strings from the Updater. I use webdownload too and when its not full downloadable it cames Try again or Exit or something. Couldnt find that stuff. In Translator it istn in.
And When Installaware is InstallAware is preparing the InstallAware Wizard which will install the application. Please Wait.
there is still the InstallAware logo. How to change this? Couldnt find the Dialog.
Thank you very much
Update Dialog translation
Re: Update Dialog translation
Run the localization tool for shared strings that are used by all InstallAware setups.
http://www.installaware.com/forum/viewt ... f=2&t=8703
Those strings are part of InstallAware Shared Strings.Where can i translate the Strings from the Updater. I use webdownload too and when its not full downloadable it cames Try again or Exit or something. Couldnt find that stuff. In Translator it istn in.
Please refer to the folowing link;And When Installaware is InstallAware is preparing the InstallAware Wizard which will install the application. Please Wait.
Ok thank you very much.
sometimes the best way is to click the whole program and read. Sry
