Not able to use Environment Variable during build
chintanpatel7
Post by chintanpatel7 »
I want to use dynamic path for source files.
For example I want to copy file from path C:\Project source
So I have set Environment Variable SOURCE_PATH to "C:\Project source" and used it in Install file command as per following:
Install Files %SOURCE_PATH%\test.txt to $TARGETDIR$
As per my thinking it should parse this command as
Install Files C:\Project source\test.txt to $TARGETDIR$
But when I try to compile or build my project it is giving me following error:
No Files matching pattern "c:\test project\%SOURCE_PATH%\test.txt"
I think this is happening because it it taking relative path to my project folder [i.e. C:\test project].
But it is not parsing value of SOURCE_PATH environment variable.
I am wondering because I have done same in my previous project and it is successfully taking source files from the path described in Environment variable used in it.
Is there anything I am missing? Please help.
Chintan
Re: Not able to use Environment Variable during build
Dear Chintan,
by the error you are receiving, I suppose the environment variable you used it is not correctly defined.
For example, I done the following;
1- Under "Control Panel ->System & Security->System->Advanced system settings->Advanced->Environment variables", I defined MYPATH = c:\mypath under System variables.
2- Restarted the system
3- Finally I used "%MYPATH%\myfile.rtf" with the Source Path parameter of the Install Files command.
... and works!
chintanpatel7
Hi Francesco,
Yes it was my fault. I have set the environment variable, used it properly but DIDN'T RESTART... :oops:
I have restarted the system and now it is working fine... :D
Thanks a lot,
Chintan
:D
