what's the best way to preserve shortcuts? After uninstallation, some shortcuts should remain.
Thank you,
Markus
Preserve Shortcuts
Preserve Shortcuts
Markus Diettrich
Install[b]Aware[/b] MVP
[i]If it can't be done with InstallAWARE then you are not using Windows[/i]
Hi Markus!
Windows Installer does not let you preserve shortcuts on the system. The only alternative would be to create them manually yourself (using, for example, a plug-in).
