Noob needs direction
cuetipper
Postby cuetipper » Fri Mar 22, 2013 11:36 am
What I would like to be able to do is to create virtual apps from existing installed software and be able to run them from my flash drive without leaving traces on the target pc that the software has run.
What version will I need?
Also if the existing software is on a win 7 x64 machine what need I do to make it run on an xp pc?
Re: Noob needs direction
Postby FrancescoT » Mon Mar 25, 2013 8:25 am
you could start with using our Trial version of InstallAware virtualization, available from;
http://www.installaware.com/virtualization
You can run your virualized app from a flash drive without any problem.
It should work without problems but of course it depends also, on how your software works.
Return to “Non-Technical”
Users browsing this forum: No registered users and 17 guests
