Service Dependency Error On Compilation
vsaeternautocrib
Postby vsaeternautocrib » Mon Mar 25, 2013 7:13 pm
I've tried to compile a service with a dependency with MSSQL$SQLEXPRESS service. When I add in MSSQL$SQLEXPRESS in the field labeled "Dependencies on Services and Load Order Groups" the compilation errors during the build with:
Error during build: Unable to compile MSI action install service
When I remove the dependency, there is no error and finishes building. I did try removing the $ character and the build finishes as well so it is my conclusion the $ is the problem. Is there maybe another way to enter the SQL Instance (SQLEXPRESS) as a dependency?
Re: Service Dependency Error On Compilation
Postby FrancescoT » Tue Mar 26, 2013 8:15 am
what InstallAware version are you using?
Honestly, I just tried to the same and my project compiles correctly.
vsaeternautocrib
Postby vsaeternautocrib » Tue Mar 26, 2013 9:57 am
I am using the Installaware Studio version 15. I've attached the project files. Could be something I'm doing incorrectly. In the project, I have the ASPSync service dependency set to MSSQL$SQLEXPRESS. I get the error when compiling. When I remove it, no errors.
ASPSyncInstaller.zip
(2.82 MiB) Downloaded 365 times
Postby FrancescoT » Tue Mar 26, 2013 11:24 am
Ok, I'll verify it.
Postby FrancescoT » Wed Mar 27, 2013 10:15 am
... ok, I found the same.
Please try with passing a variable with Service name Dependancies.
I used;
Set Variable MYDEP to MSSQL$SQLEXPRESS
... and worked fine.
NOTE.
The command documentation reports that variables are not allowed with "Dependancies" command parameter using Windows Installer.
I will log a note to our dev team, because this seems not true.
vsaeternautocrib
Postby vsaeternautocrib » Wed Mar 27, 2013 4:44 pm
Thank you. I'm not exactly sure how to pass this variable to the service installing. Where exactly did you placed this line?
Postby FrancescoT » Thu Mar 28, 2013 8:18 am
in your main script code (MSI code view in IA IDE), declare a custom variable just before the "Install Service" command call.
Then use the variable value with "Dependancies" command parameter (the variable must be dereferenced when passed as parameter).
"The syntax for dereferencing a variable in InstallAware is enclosing the variable name between dollar signs. For instance, if the variable is called MYVAR, dereference the variable using $MYVAR$. You may freely combine multiple dereferenced variables in your string literals."
Finally your code should be as below;
Install Service ..\ProjectFiles\ASPSyncService.exe to $TARGETDIR$ as ASPSyncService
Users browsing this forum: No registered users and 157 guests
