IA 12
Not sure why this was even implemented, but can we disable the way miabuild.exe turns the console transparent during it's build? Couldn't find it on google or these forums.
how to disable transparency of miabuild console
Re: how to disable transparency of miabuild console
I think this thread:
http://www.installaware.com/forum/viewt ... f=2&t=6760
explains what some of us also discussed a while back. It seems you can't turn off the "glass".
Wow, ok. Thanks.
