Access Violation when cut multiple objects
mikKummerfeld
Post by mikKummerfeld »
Hey Guys,
I found an Access Violation Message and after that miaui.exe dies...
1. Goto to Dialog Layout Editor (User Interface Editor)
2. Select multiple objects e.g 2 Checkboxes
3. Press CTRL+X to cut them
Bumm
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: Access Violation
Dear Heiko,
I'm not able to replicate the same following your steps.
mikKummerfeld
I can reproduce always....I thoght you can...move the object before you cut them...and it must be multiple
Kind regards
Heiko Kummerfeld
MIK GmbH
Dear Heiko,
I have been able to reproduce it, but doesn't happen always... I'll add it to our fix list.
mikKummerfeld
thank you so much...maybe in 15,xx version ?
Kind regards
Heiko Kummerfeld
MIK GmbH
