Where is $ALLAPPDATA$ defined?
somnetics
Post by somnetics »
A file that I have designated as going to $ALLAPPDATA$ ends up under the c:\program Files path. How can I explicitly set this?
Re: Where is $ALLAPPDATA$ defined?
By default, the ALLAPPDATA variable is initialized as;
Get Common Folder Location System->Application Data Directory into ALLAPPDATA
somnetics
Post by somnetics »
I thought so. That's why I was surprised to find the file in a folder under the folder that the executable is stored it.
I didn't create this project. Does this say that the project is not using the default location?
Yes probably, but I can't be sure of intentions of those who created the project.
or... an unwanted variable assignment.
somnetics
Post by somnetics »
I searched the MSI for all instances of AllAppData and the only time it is initialized is the line you talked about above.
Can something in the project affect what "Get Common Folder Location System->Application Data Directory" returns?
Which is tha IA version you are using?
somnetics
Post by somnetics »
InatallAware NX (Build 10.02.12) Mooooya
Thank you for your help.
could you please use the attached sample project?
The sample retrieves the "Application Data Directory" for allusers (if applicable) and for current user.
The enclosed file also contains the ready to run exe package.
When execute on a WIN 7 machine, it should display the following results.
The attachment output.gif is no longer available
allppdatatest.rar
(1.34 MiB) Downloaded 414 times
