I work with InstallAware 11.
In my setup I share a folder. (e.g. C:\progam files\myapp\test)
Then I want to set this folder to "read" permission for everyone
I added the "Set Access Control" in my MSI Code.
Object Type: File System
User: everyone
Access Rights "Read"
After building and run setup the folder C:\progam files\myapp\test is shared. Rights click on properties, Tab Security shows Permission "Read" for Everyone.
This will be correct.
But in "Properties" tab Share and here click on Authorisation Everyone has all permissions , Full Access, Change and Read for Share Authorisation!
I thinks this is not ok? It should also be only "Read"
Thanks for any help
best regards
Hans
Bug in Set Access Control?
Re: Bug in Set Access Control?
Dear Hans,
I'll check it.
However, Currently I can only verify if a possible issue can be replicated using IA 16.
I'll check it.
Dear Francesco
may I ask if you have checked this behavior with Full Access?
regards
Hans
regards
Hans
Dear Hans,
yes, I have verified it and Set Access Control commad worked fine with all my tests.
As I told you previously, I used IA 16 to verify the behavior you seems to have.
