Problem in Dialog Editor after upgrading to IA16
alibaba
Post by alibaba »
I have updated to IA16 and now I cannot edit a combo-box in my dialog. I think it is because of some characters in the item list, look attached picture. What can I do, do I have to built the dialog completely new?
EDIT: this is what was insert as items:
Deutschland
Österreich
Schweiz (deutsch)
Schweiz (französisch)
Frankreich
Großbritannien
USA
Error after klicking the item edit button in the dialog editor.
Re: Problem in Dialog Editor after upgrading to IA16
Dear Alibaba,
could you post the dialog file? ... I would like to have a look.
alibaba
Post by alibaba »
No problem, hope this is what you need.
I think the problem is that I had insert "unicode" characters in the item list that are now converted and not readable.
dialog.ZIP
(3.08 KiB) Downloaded 477 times
Dear Alibaba,
I just tried with IA 16 ... and it seems to work fine.
alibaba
Post by alibaba »
Yes I can also "run" the dialog. But have you tried to edit the items of the combo box!?
You will get the error...what to do now.
Dear Alibaba,
I found the same and I have already posted a note about it to our dev team.
Dear Alibaba,
the issue has been fixed with the latest IA 16 updates.
redbyron
Post by redbyron »
Hi Francesco,
i rebuild my license on 29/7/2013 and applied it.
Version number is 7.23.13 and still does not work.
Is there any hotfix available? Also could you synchronize versions numbers,
eg when you say 16.07 then version window should also say 16.07 and not the build date
Thank you in advance,
Michael
Regards,
Michael
Dear Michael,
IA version 16.07 (which it is the most recent update available), requires complete product re-installation if not updating from IA 16.06 version.
Did you do that?
I have personally verified this issue and I'm sure that it has been fixed.
Note.
IA version numbers are syncronized ... but currently the IA IDE reports the build number only.
The IA version installed can be verified via ARP (... under Control Panel).
redbyron
Post by redbyron »
Hi Francesco,
i downloaded the full 16.07 setup (2.1 Gb) and reinstalled (in ARP it showed 16.0.0.2013, after setup 16.0.7.2013). Then i applied my latest license and it worked. But i must admit that this is much unconventional, as it took much time to remove installaware 16, reinstall installaware 16 and then apply the latest patch/license. It also lost all the last used projects list etc.
I suggest to make more clear in blog posts when we must download full version, or just apply the license/patch in order to upgrade.
Thank you for your help and quick responding,
Michael
Regards,
Michael
bokkie
Post by bokkie »
redbyron wrote:Hi Francesco,
...It also lost all the last used projects list etc...
Michael
Michael, refer to this thread http://www.installaware.com/forum/viewt ... f=2&t=8593. It identifies where the file is that contains the MRU. It's too late now I think, but when you upgrade next save the file and copy it back afterwards. I haven't verified it but perhaps you can edit the file and add the missing MRUs you like to use.
