Problem while adding setup.exe to Patch builder
jayant
Post by jayant »
While adding the old setup file in patches. Installaware stops responding and C drive gets full. A temp file gets created in C drive which gets bigger in size untill installaware is closed. Please help and thanks in advance.
Re: Problem while adding setup.exe to Patch builder
Dear Jayant,
By the only information you shared, it is really difficult to find out what happens on your side.
For example, which is the size of those files you are adding as patch reference?
Are you sure there is enough free space on your system?
jayant
Post by jayant »
Im adding only the single setup exe which is 216 MB.
I have 30GB space free in C drive, If I delete the temp file.
Dear Jayant,
Really strange. I never seen a similar problem.
... which is the full path of the setup you are adding as reference?
