Changing permissions for a file in system32 (64 bits)
frank5625
Post by frank5625 »
I made a very small and simple installaware installation program which simply installs a file in system32 folder and gives everyone read/write permissions on this file.
It doesn't work. I also tested the same steps in another folder and it works.
I'm using InstallAware Studio 15. It's a native 64-bit project on a 64 bit Win 7 machine.
I've tried with a dll and a simple empty text file. It works on a native 32-bit project.
On a native 64-bit project the result is the following:
The file gets copied (installed) but permissions aren't set.
After Define Setup Globals' end region:
[DEFINE REGION: MyProject]
Install Files abc.txt to $SYSTEM32$ (Permanent, Never Overwrite)
Apply Install
Set Read Write Permissions on File System Object "$SYSTEM32$\abc.txt" for Everyone
Install Files abc.txt to C:\ (Permanent, Never Overwrite)
Apply Install
Set Read Write Permissions on File System Object "C:\abc.txt" for Everyone
[END REGION]
Thanks a lot!
Re: Changing permissions for a file in system32 (64 bits)
Dear Frank,
First of all:
did you explicitly set with your script that you are installing a native 64 bit package?
This behavior is controlled by the statement:
If don't declare the above code, your package runs as NATIVE 32 bit.
Consequently, the System32 folder will be redirected to "C:\Windows\SysWOW64" instead of "C:\Windows\System32".
frank5625
Post by frank5625 »
Sure. In fact I never had to set it manually. It was already done when I created the project.
I've attached the mia.txt file of my project. The only code I added starts at line 232 and ends at line 237
New Project64.mia.txt
(9.2 KiB) Downloaded 487 times
Here are the steps I done:
- Create new project: New project Templates -> Win64 Setup
- Then I wrote the few lines of code after the comment "TO-DO: Insert any additional install commands here"
~InstallAware Clipboard Data~
~Apply Changes~
~{40EC5702-EC50-4679-B470-F233CD63B0B0}~
~TRUE~
~FALSE~
~Install Files~
~{A0205275-5E84-48B7-AE7E-37552FA53BFF}~
~abc.txt~
~FALSE|~
~C:\~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~TRUE~
~TRUE~
~Set Access Control~
~{DEB8ED29-6D1B-4B5A-9EE9-0E39CC10EEBA}~
~$SYSTEM32$\abc.txt~
~TRUE~
~FALSE~
~FALSE~
~FALSE~
~TRUE~
~TRUE~
~TRUE~
~FALSE~
~FALSE~
~TRUE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~Apply Changes~
~{591BFBEB-CA10-421E-9C6B-075674A14DFA}~
~TRUE~
~FALSE~
~Install Files~
~{0F66E9A0-F1D1-4F5A-B01E-5ABCB9234E43}~
~abc.txt~
~FALSE|~
~$SYSTEM32$~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~TRUE~
~TRUE~
Dear Frank,
... let me check it.
frank5625
Post by frank5625 »
Dear Francesco,
Have you had any time to check it?
Thanks!
Dear Frank,
Yes, it seems that I found the same.
Currently, I may suggest you to use the "CALCS" utility as workaround to have those setting applied.
First install those files;
 Install Files abc.txt to $TARGETDIR$
Install Files abc.txt to $WINSYSDIR$
then just after Apply Install;
Comment: Set Read Write Permissions on File System Object "$WINSYSDIR$\abc.txt" for Everyone
Set Read Write Permissions on File System Object "$TARGETDIR$\abc.txt" for Everyone
Run Program cacls "$WINSYSDIR$\abc.txt" /e /grant Everyone:R
Run Program cacls "$WINSYSDIR$\abc.txt" /e /grant Everyone:W
The same as InstallAware Clipboard format;
~Run Program~
~{A75F1AB8-40D6-460A-8A78-BA9DF935CCFE}~
~cacls~
~FALSE~
~"$WINSYSDIR$\abc.txt" /e /grant Everyone:W~
~FALSE~
~Run Program~
~{F9A9803E-6F09-41A4-AA21-ECCB6C243625}~
~cacls~
~FALSE~
~"$WINSYSDIR$\abc.txt" /e /grant Everyone:R~
~FALSE~
~{BEC33A14-ADEA-4842-B24A-261F22E9AF63}~
~$TARGETDIR$\abc.txt~
~TRUE~
~FALSE~
~FALSE~
~FALSE~
~TRUE~
~TRUE~
~TRUE~
~FALSE~
~FALSE~
~TRUE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~{2CA40A60-79A5-406A-8D17-992F215EA3FC}~
~$WINSYSDIR$\abc.txt~
~TRUE~
~FALSE~
~FALSE~
~FALSE~
~TRUE~
~TRUE~
~TRUE~
~FALSE~
~FALSE~
~TRUE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~{C356712F-F403-45A5-8FF9-EDCE64A102AD}~
~C:\abc.txt~
~TRUE~
~FALSE~
~FALSE~
~FALSE~
~TRUE~
~TRUE~
~TRUE~
~FALSE~
~FALSE~
~TRUE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~Apply Changes~
~{5F6CD929-F41B-480A-974E-51CAC4CAFD8F}~
~progress~
~SUCCESS~
~TRUE~
~FALSE~
For more details on how to use the "CALCS" utility, please refer to the available Microsoft documentation.
PS.
With more recent OSes as WIN 7 "ICALCS" should be used instead of "CALCS" ... I just tried using the above code snippet and it works fine.
frank5625
Post by frank5625 »
Dear Francesco,
Thanks a lot. It works now. Is this issue fixed in the latest version (17)?
PS:
I ended up using cacls (instead of icacls) since I want it to work on both XP and Win7. Plus, the line is more like this:
Run Program cacls "$WINSYSDIR$\abc.txt" /e /g Everyone:R
Thanks again!
I happy you solved!!
I tested the issue with IA 17.
