Wise Script conversion evaluation
kjullion
Postby kjullion » Thu Aug 08, 2013 9:39 am
I'm trialing the conversion of some of my Wise scripts and I'm confused as two why the following Wise command
item: Compiler Variable If
  Variable=_COMPANY_
  Value=XYZCo
when converted by InstallAware comes over exactly the opposite of what the Wise command does.
[compiler if Variable _COMPANY_ not Equals XYZCo]
Why is InstallAware putting in the "not"?
Does it have a problem with the way in which my compiler variable (in this case it's "_COMPANY_") is named?
Re: Wise Script conversion evaluation
Postby FrancescoT » Fri Aug 09, 2013 4:16 am
Unfortunately, I have do admit that what you found it is an error with converting the conditional Compiler variable statement from Wise.
I'll drop a note about it to our dev team.
At the moment I can only suggest that you to manually correct the conditional evaluation.
kjullion
Postby kjullion » Fri Aug 09, 2013 11:32 am
Ok, thanks. I may have found a different problem too; or maybe I did something wrong...I'm not sure.
In the WISE script below we are checking two Configuration settings (first) that the user's OS has the Win 95 Shell interface and (second) that they have Admin rights. I realize the Win 95 Shell Interface is an old and proabably out-dated test, and this is probably why the converter decides it's OK to comment out that test, but it only seems to comment out the "If" part of the test and not the "End If" part of the test, which means that after conversion I am left with a mis-matched pair (no "If", but a leftover "end if").
item: Remark
  Text=Set to Long filename
item: Set Variable
  Variable=MAINDIR
  Value=%MAINDIR%
  Flags=00010000
item: Check Configuration
  Flags=10111011
  Flags=10111111
item: Remark
  Text=This will update the Registry with the App Path entered by user
item: Edit Registry
  Total Keys=1
  Key=SOFTWARE\%DEFAULTDIR%\CurrentVersion
  New Value=%MAINDIR%
  Value Name=AppFolder
  Root=2
  Variable=_INSTALLTYPE_
  Value=Setup
item: Edit Registry
  Total Keys=1
  New Value=%_APPVERSION_%
  New Value=
  Value Name=SetupVersion
  Root=2
item: Compiler Variable End
item: End Block
item: End Block
Here is the post-conversion IA script:
 Comment: Set to Long filename
 Set Variable MAINDIR to $MAINDIR$
 Convert to Long Path: MAINDIR
 Comment: Check Configuration: <Windows 95 Shell Interface> not supported
 Get System Setting Administrator Rights into CHECKCONFIGURATIONVAR
 if Variable CHECKCONFIGURATIONVAR Equals TRUE
   Comment: This will update the Registry with the App Path entered by user
   Write Registry Key HKLM\SOFTWARE\$DEFAULTDIR$\CurrentVersion\AppFolder, $MAINDIR$
   [compiler if Variable _INSTALLTYPE_ not Equals Setup]
   Write Registry Key HKLM\SOFTWARE\$DEFAULTDIR$\CurrentVersion\SetupVersion, $_APPVERSION_$
   [compiler end]
Notice the two "end" statements and only one "If" statement.
Thanks!
Postby FrancescoT » Mon Aug 12, 2013 8:40 am
... let me check ... for sure it seems to be not correct.
Return to “Non-Technical”
Users browsing this forum: No registered users and 1 guest
