if I use "Read From Text File" function to read a file I get the error that after reading the first line contains strange symbols. The file to read is ANSI and it starts with following line:
# application startup properties
after writing the line back to file ("Write into Text File") it contains the following:
Our application has problems reading that file. And I am modifiing the file only in line 4 and 5. What can I do to avoid this bug?
Best regards!
Problems with "Read From Text File"
Re: Problems with "Read From Text File"
Dear Alibaba,
have you tried with adding an empty string at the very beginning of your text file?
Hi Francesco,
I solved the problem by directly editing the file, without reading and writing it back. But this was always working until IA 16 or 17.
Users browsing this forum: No registered users and 34 guests
