Single file build
anja_laenge
Single file build
Postby anja_laenge » Wed Aug 28, 2013 9:11 am
creating a setup that contains the .NET framework 4 I get the following output when using the Single file build mode:
a folder Release\Single with a setup.exe and a data folder with four files:
\data\Microsoft .NET Framework 4 (x64)\mFileBagIDE.dll\bag\Windows\Microsoft.NET\Framework\v4.0.30319\ASP.NETWebAdminFiles\Security\Permissions\App_LocalResources\managePermissions.aspx.resx
\data\Microsoft .NET Framework 4 (x64)\mFileBagIDE.dll\bag\Windows\Microsoft.NET\Framework64\v4.0.30319\ASP.NETWebAdminFiles\Providers\App_LocalResources\manageconsolidatedProviders.aspx.resx
\data\Microsoft .NET Framework 4 (x64)\mFileBagIDE.dll\bag\Windows\Microsoft.NET\Framework64\v4.0.30319\ASP.NETWebAdminFiles\Security\Permissions\App_LocalResources\createPermission.aspx.resx
\data\Microsoft .NET Framework 4 (x64)\mFileBagIDE.dll\bag\Windows\Microsoft.NET\Framework64\v4.0.30319\ASP.NETWebAdminFiles\Security\Permissions\App_LocalResources\managePermissions.aspx.resx
\data\Microsoft .NET Framework 4 (x64)\mFileBagIDE.dll\bag\Windows\Microsoft.NET\Framework64\v4.0.30319\ASP.NETWebAdminFiles\Security\Wizard\App_LocalResources\wizardAuthentication.ascx.resx
The setup seems to work fine without the data folder. So, why is it there, what purpose does it have?
Using InstallAware 15 Studio edittion.
Thnx in advance
Anja
Re: Single file build
Postby FrancescoT » Wed Aug 28, 2013 10:02 am
Dear Anja,
you can safely ignore those files ... it is a know problem.
Them should be removed by the build process but, "unfortunately" in some circumstance this doesn't happen.
anja_laenge
Postby anja_laenge » Thu Aug 29, 2013 1:38 am
Thanks!
Postby FrancescoT » Thu Aug 29, 2013 9:57 am
:D
Users browsing this forum: Baidu [Spider] and 61 guests
