UCS 16 in Installaware
alfrqan
Postby alfrqan » Fri Sep 20, 2013 2:14 pm
hello
I do need to read user input which might be hard to be saved in a variable such "-›Ĩsтąяĩ‹-"
is it possible to let installer read UCS 16...I am using installaware15
i did define a variable in start of the project msi codes
I tried many trials such those
Set #CODEPAGE# to 1200
Set #CODEPAGE# to OEM_CHARSET
Set CODEPAGE to OEM_CHARSET
Set CODEPAGE to 1200
Set Variable CHARSET_OVERRIDE to OEM_CHARSET
this seems only for dialoges(CHARSET_OVERRIDE )
I tried adding compiler variable from project settings
tried
variable: CODEPAGE default value:1200
all not working any help?
alfrqan
Re: UCS 16 in Installaware
Postby alfrqan » Fri Sep 20, 2013 2:25 pm
my Project Installaware15
EE.rar
Project if you need to see it
(1.53 MiB) Downloaded 577 times
Postby FrancescoT » Tue Sep 24, 2013 2:41 pm
... honestly, I'm quite a bit confused about your question.
If you are trying to aquire or to store an UNICODE string ... this is not possible with IA 15 because UNICODE support has been introduced with IA 16.
Users browsing this forum: Google Adsense [Bot] and 101 guests
