Problem with scripts
mikKummerfeld
Post by mikKummerfeld »
Hey Guys,
how can I solve this problem:
I have a script with an insert script command. In this calling script there is a label at the start e.g ":label begin".
When I call this script in my main script more than one it does not work.
How would you solve that? I dont want to copy this script 30 times to be able to call it 30 times
Thanks...
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: Problem with scripts
Dear Heiko,
How do you call the script?
Are you using the "include Script" statement each time you need it in your main script?
mikKummerfeld
Yes of course I do...is there a better way doing this ????
Kind regards
Heiko Kummerfeld
MIK GmbH
No, there isn't.
mikKummerfeld
Bad... !
So do I really have to duplicate my script 30 times to call it 30 times ???
Like ImportScript, ImportScript02, ImportScript03....???
Kind regards
Heiko Kummerfeld
MIK GmbH
... you only have to duplicate the Import Script statement ... not the script file inclusion itself.
Honestly, I don't understand your comment ... it is the same if you need to call a fuction 30 times with any Code editor. isn't it?
mikKummerfeld
no it does not work...I cant include a script multiple times because I have a Label in the script with goto labels inside this script and there Comes a ERROR MESSAGE while building...
The Compiler "thinks", that I have "my Label" multiple times, because I insert the same script more than one..
SEEMS A BUG !
1. Create a script like this
:Label
goto Label
2. insert this script in main script 2 times
3. Build => BÄÄÄM
Kind regards
Heiko Kummerfeld
MIK GmbH
Dear Heiko,
it is not a bug ... it is simply because you can't use a label statement as you are doing.
You must keep in mind that a script ... it is not a function ... and due of this, you should use labels within your main script only or include your script one time only.
Otherwise a "multiple label declaration" error is returned
Hope this clarify your doubt.
