progress as output of a silent installation
stefan.nieten
Postby stefan.nieten » Thu Oct 10, 2013 4:52 am
Hi InstallAware-Team,
is it possible with IA17 to get the installation progress information of a silent installation directly as output of the installer executable? We want to start a installer executable from another program as a sub installer and show the progress information within the program's gui. Not just show and hide the installer gui, which was mentioned in http://www.installaware.com/forum/viewtopic.php?f=2&t=5703 and http://www.installaware.com/forum/viewtopic.php?f=2&t=6469.
Thanks in Advance!
greets,
stefan
Re: progress as output of a silent installation
Postby FrancescoT » Thu Oct 10, 2013 10:27 am
Dear Stefan,
If I haven't missed anything, you can use the "(Un)Install MSI Setup" command to execute that package silently, but with displaying its installation progress within the caller package.
The (Un)Install MSI Setup plug-in provided command installs, re-installs, or uninstalls a Windows Installer setup. A full Windows Installer setup command line may be specified. The progress of the Windows Installer setup will be captured and displayed as part of the installation progress.
stefan.nieten
Postby stefan.nieten » Thu Oct 17, 2013 4:52 am
Hi Francesco,
okay thank you. But yes we want to get the progress information as output of the installer (msi/exe) to show it in our custom gui.
I just found this stackoverflow article about this:
http://stackoverflow.com/questions/1659 ... -cancel-it
Maybe there are other possibilities to get the progress information of the installer.
best,
stefan
Postby FrancescoT » Thu Oct 17, 2013 11:06 am
Dear Stefan,
but if you want to follow what suggest by the link, you only need to run that package using the "run Program" command from your installer.
Obviously, doing this the msi/exe package that you execute will use its own interface and it will be not integrated in your setup UI as I suggested previously.
am I missing something?
stefan.nieten
Postby stefan.nieten » Tue Oct 22, 2013 6:13 am
Hi Francesco,
we are alreay use the "run program"-cmd to execute sub installers in our installers. The progress information from the sub installers is also visible in
the main installer gui. So this works fine.
But now we would like to execute an installer executable/msi which was built with InstallAware in another c++-application and display the installation progress within the application's gui. In the last post of the stackoverflow article it is mentioned, that it could be done by using the MSI-Api to execute the installer-msi and specify an external UI handler using MsiSetExternalUI or MsiSetExternalUIRecord.
Thanks for your support!
best,
stefan
Postby FrancescoT » Thu Oct 24, 2013 3:09 am
Dear Stefan,
you could try this sample;
http://msdn.microsoft.com/en-us/library/bb309215(v=vs.85).aspx
stefan.nieten
Postby stefan.nieten » Tue Oct 29, 2013 4:20 am
Hi Francesco,
okay thx. I modified the sample so that progress information of msi packages is messaged to stdout. I used some msi packages and progress data was messaged. Then I tried it with an InstallAware' built msi package (Standard Win32 Template, umcompressed build), but no progress infomation was returned. Do you know why this is the case?
Thanks in Advance!
greets,
stefan
Postby FrancescoT » Tue Oct 29, 2013 12:52 pm
Dear Stefan,
... I never used that code.
stefan.nieten
Postby stefan.nieten » Thu Dec 05, 2013 9:37 am
Hi Francesco,
but do you know another way than using the MSI-API to get progress information of Installers which were build with InstallAware? As I said for other MSI-Installers the Solution with "MsiSetExternalUIRecord" worked. Those Installers messages the installation progess and we could show the data in our custom gui progress bar. Or is the conclusion that their is no way to get installation progress data out of InstallAware-Installers? It is really imprtant for us to know.
Thank you!
greets,
Stefan
Postby FrancescoT » Thu Dec 05, 2013 11:38 am
Dear Stefan,
... I'll forward your answer to our dev team.
stefan.nieten
Postby stefan.nieten » Tue Dec 17, 2013 4:50 am
Hi Francesco,
okay thank you. Did you already got new information on this from the dev team?
regards,
Stefan
Postby FrancescoT » Tue Dec 17, 2013 5:15 am
Dear Stefan,
Unfortunately Not yet.
Of course, I'll be back to you as soon I receive a reply.
jrowles
Postby jrowles » Tue Sep 09, 2014 8:08 pm
I am also interested in receiving an answer to this. I am invoking the installation from a C# WinForm application and would like to receive progress information (the text beneath the progress bar) so I can post it to my WinForm application.
Thanks in advance.
Postby FrancescoT » Wed Sep 10, 2014 11:00 am
Unfortunately, nothing new on this.
Users browsing this forum: No registered users and 85 guests
