InstallAware Virtualization & SQL LocalDB
kehagiem
Post by kehagiem »
The idea of using the new InstallAware Virtualization to create a single truly portable executable file,
which could reside on a network location, or a USB drive is great.
However, I have an application that uses SQL LocalDB, can I use Installaware Virtualization product to create a single executable install?
Thanks in advance,
Emmanuel
Re: InstallAware Virtualization & SQL LocalDB
Dear Emmanuel,
If you mean, to embed SQL LocalDB with your Virtualized application; No, that is not possible.
If SQL local DB is installed on the target machine; Yes, virtualized applications may be used with it.
kehagiem
Post by kehagiem »
Thanks. Your answer is very clear.
Regards,
Emmanuel
:D :D :D
