HTML View - How to remove the scroll bar.
hdwivedi23
Post by hdwivedi23 »
I am using a HTML view to display images in rotation on progress dialog. When I use the installer on a machine with low resolution the images in HTMLView don't resize and HTMLView displays horizontal and vertical scrollbars. That look ugly.
Is there a way to resize the images in the HTMLView based on resolution? I just want the scrollbars to go away. I am using Installaware 17 studio.
Re: HTML View - How to remove the scroll bar.
It is not possible to re-size those images from the control and honestly, I never seen an HTML control that has these capabilities.
You should try with creating an HTML resource that displays at best on all most resolutions ... otherwise, try with using use an Image instead of an HTML resource.
