Runtime Error - prereq.dfm The system cannot find the file..
Presslr1
Postby Presslr1 » Thu Oct 24, 2013 10:34 am
I am using InstallAware 17 on Windows 8 with Visual Studio 2005. I receive no errors when building the project. When I go to install the application, I receive Runtime Error in the InstallAware Wizard "C:\Users\Robert\AppData\Local\Temp\mia3\prereq.dfm". The system cannot find the file specified.
I downloaded procmon.exe and the only thing that I could find was pointing to the setup.exe file for the app I am trying to install. I have tried to two different computers. All Anti-Virus is disabled.
Can anyone help me out with this? Many thanks!
Re: Runtime Error - prereq.dfm The system cannot find the fi
Postby FrancescoT » Thu Oct 24, 2013 11:47 am
Are you able to replicate the same with a very simple project?
Presslr1
Postby Presslr1 » Fri Oct 25, 2013 6:04 am
FrancescoT wrote:Are you able to replicate the same with a very simple project?
Hello, FrancescoT, no, on a very simple project, I do not have this issue.
I noticed in my original project Project/InstallAware directory, there are only 9 files; whereas, in my simple project/InstallAware directory, there are many files...didn't count them.
Another clue that may help, is for my original project, the last time I upgraded the application in 2011, I was using Windows 7 and an earlier version of InstallAware. The original InstallAware build directory is still in the same location, but since I upgraded InstallAware, I renamed the InstallAware folder to force a new set of files. I am not sure why I did that other than because I upgraded InstallAware. However, I have also tried to create a successful install using the previous build directory files, but that didn't seem to work either.
Postby FrancescoT » Fri Oct 25, 2013 11:26 am
Dear
I suspect that simply ... you missed to copy ( for some reasons) the required "prereq" dilaog resources within your project folder.
Please check if both "prereq.dfm" and "prereq.dfm.miaf" files are available under your project folder.
... probably due the fact that you don't have so many files under the project folder, those are not the only you missed.
So, carefully check the files under your original project folder.
Users browsing this forum: Google Adsense [Bot] and 100 guests
