I have a project where at the end a few libraries are registered. This worked well for years. But since the last version of IA I always got a setup crash during the registration. I built a batch file that registers the libraries now and call it instead of "register library" this is working well. Also a test with the previous IA version failed.
Any ideas what could be the problem?
A minimum reproducing project could be a problem since this product is really big if I integrate all the dependencies for the libraries.
Best regards
Problems with register libraries through IA
Re: Problems with register libraries through IA
Dear Alibaba,
honestly, I don't know what could be the problem.
Anyway, if can supply to me one of those libraries or if you could release a minimal project that only tests the "register Library" comman (...this will be better), I'll try to verify it.
Users browsing this forum: No registered users and 53 guests
