InstallAware Express: 32 bit and 64 bit installer Combined
DSMyers
Postby DSMyers » Mon Oct 28, 2013 11:14 am
How do I set up InstallAware Express 18 to generate a single installer that will install our application (which can run either 32 or 64 bit) on both 32 and 64 bit platforms. Specifically, I am looking to have it installed in Program Files on both systems (not Program Files (x86) on 64-bit systems). Thanks for your help.
Re: InstallAware Express: 32 bit and 64 bit installer Combin
Postby FrancescoT » Tue Oct 29, 2013 12:27 pm
I believe that the "Win64 setup" InstallAware project template does exactly that.
isn't it?
DSMyers
Postby DSMyers » Tue Oct 29, 2013 12:35 pm
I'm not sure. I am using an installer project that was created long ago. I'll look at the Win 64 template and see what I can find out. Thanks for the suggestion.
DSMyers
Postby DSMyers » Tue Oct 29, 2013 5:26 pm
I just heard from the vendor that, despite what their web site says, you cannot create a Hybrid installer with InstallAware Express. I thought I'd include that here in case someone else has this question.
Postby FrancescoT » Wed Oct 30, 2013 11:24 am
so ... did you solved?
DSMyers
Postby DSMyers » Wed Oct 30, 2013 1:43 pm
No. I abandoned the project because the cost of upgrading to a version of IA that would support building a hybrid installer was too high. I also uninstalled the upgrade I purchased to get this capability and my money was refunded.
Users browsing this forum: No registered users and 164 guests
