Persistent variable
maurosturaro
Persistent variable
Post by maurosturaro »
Sorry I've not undestood how to use persistent variable.
I've seen that the first reference of a variable in the script must be a 'Set Variable' or I get a runtime error of 'Attenpting to get value of undefined variable'.
But doing so I overvrite the persisted value that i can see in the debugger.
What's wrong in my usage ?
You could say:
if Variable MAINTENANCE Equals FALSE
  Set Persistent Variable MYVARIABLE to VALUE
all the way on top of your script. This way the compiler will be happy, and the variable will not be overwritten on future runs of your script.
Note: The typical place for this type of first-time initialization in the setup code is the place marked:
  Comment: First Time Install
in the setup script. Choose "Comments" on the left combo box and "First Time Install" in the right combo box (both located on top of your script, below the tabs) to quickly locate this place.
