Unable to import .REG file
kpm30519
Post by kpm30519 »
Hi--
I am upgrading an older program written with Wise. I have exported the registry settings from Wise to a *.REG file, to import into IA16. In IA16, in the Registry section, I click IMPORT, select my REG file, watch the little activity indicator for a bit, and then...nothing. No entries are imported from the file into IA. I have tried exporting as both a ver4 REG file, and a ver5 REG file with the exact same results. I have tried importing into variuos locations into the registry, and still nothing.
Thoughts?
K.
Re: Unable to import .REG file
honestly, I just tried and the REG file import works fine.
Probably, I can only suppose that your REGISTRY view in the IDE doesn't refresh immediatelly ... maybe.
kpm30519
Post by kpm30519 »
If it was a display issue, changing views, refreshing or restarting the IDE would resolve it. It does not. There are no new WRITE REGISTRY KEY entries in the MSICode tab either. The data is simply not being imported, though it looks as if something is happening. FYI, running Win7 64- bit.
... I used Win 7 x64 as well.
Try to post your reg file.
kpm30519
Post by kpm30519 »
Here's the reg file, as requested.
HKCR.zip
(1.7 KiB) Downloaded 1210 times
... let me check it.
I just used your REG file ... and honestly, I don't see any problem with importing it.
kpm30519
Post by kpm30519 »
Well, no matter what I do, it does not work for me. I've even started a new native project, completely empty, and it acts as I've described before. Can I ask, will you send me the code of the reg entries? It will save me a bit of time over entering them manually.
Below you find the code as InstallAware ClipBoard format.
~InstallAware Clipboard Data~
~Write Registry~
~{F9837694-F2E6-4983-A6E7-04C38B071F3B}~
~0~
~0~
~.awao~
~ClickForms.Document~
~TRUE~
~FALSE~
~Write Registry~
~{A5A4EA99-72FA-405A-9A89-F684EFCE88B6}~
~0~
~0~
~.awao\ClickForms.Document\ShellNew~
~TRUE~
~FALSE~
~Write Registry~
~{D01E1AA3-E331-43B5-AB7A-00E59557FE72}~
~0~
~0~
~.cft~
~TRUE~
~FALSE~
~Write Registry~
~{77320BA2-D91E-4787-8872-088C0066255E}~
~0~
~0~
~.cft\ClickForms.Document\ShellNew~
~TRUE~
~FALSE~
~Write Registry~
~{14E00313-AF0B-47CF-9D59-4F407CD20577}~
~0~
~0~
~.clk~
~TRUE~
~FALSE~
~Write Registry~
~{480D4E9E-27B1-48E5-B54F-E3A8F0245D98}~
~0~
~0~
~.clk\ClickForms.Document\ShellNew~
~TRUE~
~FALSE~
~Write Registry~
~{F1EACA5F-62B3-4F8F-94DA-65487E3C67AA}~
~0~
~0~
~.rxml~
~TRUE~
~FALSE~
~Write Registry~
~{E3B28DEB-7952-4A0A-B8C7-A3514F2E8EB6}~
~0~
~0~
~.rxml\ClickForms.Document\ShellNew~
~TRUE~
~FALSE~
~Write Registry~
~{EE18AFAD-47C5-4CAC-ABAD-0BE8F6BCC958}~
~0~
~0~
~.uao~
~OrderProcessor.Application~
~TRUE~
~FALSE~
~Write Registry~
~{8869F438-3282-4717-890A-5316A4F3159A}~
~0~
~0~
~.uao\OrderProcessor.Document\ShellNew~
~TRUE~
~FALSE~
~Write Registry~
~{F773CC4E-700D-4284-BCA0-F124AF564BCD}~
~0~
~0~
~.uao\OrderProcessor.Document\ShellNew\Open\Command~
~\"$PROGRAMFILES$\Bradford\ClickFORMS\Tools\Orders\OrderProcessor.exe\" \"%1\"~
~TRUE~
~FALSE~
~Write Registry~
~{0D4A8B89-B600-4935-976E-3B0FE6974058}~
~0~
~0~
~.xap~
~TRUE~
~FALSE~
~Write Registry~
~{DC2ACB35-4A0B-49C6-8B7F-EEA77066052E}~
~0~
~0~
~.xap\OrderProcessor.Document\ShellNew~
~TRUE~
~FALSE~
~Write Registry~
~{9F1D152D-7AD3-40B6-95AB-32149D7A3D3E}~
~0~
~0~
~.xap\OrderProcessor.Document\ShellNew\Open\Command~
~TRUE~
~FALSE~
~Write Registry~
~{1FE3F87A-01A0-4DFD-8491-BFF256554B6D}~
~0~
~0~
~ClickForms Document~
~TRUE~
~FALSE~
~Write Registry~
~{DCFD9F3F-F9A2-4B6B-B170-1130918596E9}~
~0~
~0~
~ClickForms.Document\shell~
~open~
~TRUE~
~FALSE~
~Write Registry~
~{871CAA4C-7CB5-4782-BEBE-F28067D56D7F}~
~0~
~0~
~ClickForms.Document\shell\open~
~open~
~TRUE~
~FALSE~
~Write Registry~
~{6541BD08-D316-4FCB-A418-311E3F3AFDB2}~
~0~
~0~
~ClickForms.Document\shell\open\command~
~\"$PROGRAMFILES$\Bradford\ClickForms\ClickForms.exe\" \"%1\"~
~TRUE~
~FALSE~
~Write Registry~
~{3214E544-0E95-48FD-8CCF-6B6BD97C6ADC}~
~0~
~0~
~CLSID\{33CC5481-1B8E-49CF-A109-BD3B414ED540}~
~Service.Mapping.Bradford.ClickFORMS.LocationMapService~
~TRUE~
~FALSE~
~Write Registry~
~{1B496F3A-2738-4B82-B57E-AB171EEC8028}~
~0~
~0~
~CLSID\{33CC5481-1B8E-49CF-A109-BD3B414ED540}\Implemented Categories\{62C8FE65-4EBB-45E7-B440-6E39B2CDBF29}~
~TRUE~
~FALSE~
~Write Registry~
~{089E7B96-A340-4810-BECB-151D60A6D7EE}~
~0~
~0~
~CLSID\{33CC5481-1B8E-49CF-A109-BD3B414ED540}\InprocServer32~
~mscoree.dll~
~TRUE~
~FALSE~
~Write Registry~
~{119BBDFF-C9C1-4551-8E79-DFF4FCD930DD}~
~0~
~0~
~Assembly~
~Service.Mapping.Bradford.ClickFORMS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=6b56a14211587e08~
~TRUE~
~FALSE~
~Write Registry~
~{53339170-CF7D-42F6-92D7-630FFC1A7190}~
~0~
~0~
~Class~
~TRUE~
~FALSE~
~Write Registry~
~{E8AB1BD5-024C-4D51-8BA3-EF8DD1BE0B6F}~
~0~
~0~
~RuntimeVersion~
~v2.0.50727~
~TRUE~
~FALSE~
~Write Registry~
~{A197B162-CA08-482A-BF76-2D00DA3855F4}~
~0~
~0~
~ThreadingModel~
~Both~
~TRUE~
~FALSE~
~Write Registry~
~{6F75306C-2E3D-4D01-8DB0-0A1FEC382ED1}~
~0~
~0~
~CLSID\{33CC5481-1B8E-49CF-A109-BD3B414ED540}\InprocServer32\1.0.0.0~
~Assembly~
~TRUE~
~FALSE~
~Write Registry~
~{772A8235-039A-4622-8BFF-564EAAF02086}~
~0~
~0~
~Class~
~TRUE~
~FALSE~
~Write Registry~
~{E8C1E012-99C6-44E8-B0A0-5D698605BA30}~
~0~
~0~
~RuntimeVersion~
~v2.0.50727~
~TRUE~
~FALSE~
~Write Registry~
~{73EE174A-BF8F-4DF4-8C60-E894282BABCF}~
~0~
~0~
~CLSID\{33CC5481-1B8E-49CF-A109-BD3B414ED540}\ProgId~
~Service.Mapping.Bradford.ClickFORMS~
~TRUE~
~FALSE~
~Write Registry~
~{B8D35B4A-9D5B-4BCF-B5E8-EC50150FC277}~
~0~
~0~
~CLSID\{C7678EE5-AA96-38DD-918A-970F1F7B469B}~
~Service.Mapping.Bradford.ClickFORMS.SplashForm~
~TRUE~
~FALSE~
~Write Registry~
~{E02EB982-0C77-4E6D-B79C-8B0B207ED38B}~
~0~
~0~
~CLSID\{C7678EE5-AA96-38DD-918A-970F1F7B469B}\Implemented Categories\{62C8FE65-4EBB-45E7-B440-6E39B2CDBF29}~
~TRUE~
~FALSE~
~Write Registry~
~{D9C07249-97AD-4580-923C-A43C1EA89232}~
~0~
~0~
~CLSID\{C7678EE5-AA96-38DD-918A-970F1F7B469B}\InprocServer32~
~mscoree.dll~
~TRUE~
~FALSE~
~Write Registry~
~{53E82EF0-D8A4-40C5-90E7-28F0C01E8BE3}~
~0~
~0~
~Assembly~
~TRUE~
~FALSE~
~Write Registry~
~{9F299F7C-4F35-4469-BAEE-EC296F87DCEA}~
~0~
~0~
~Class~
~TRUE~
~FALSE~
~Write Registry~
~{6C6EFC1E-2977-4E4D-B752-1F386127F736}~
~0~
~0~
~RuntimeVersion~
~v2.0.50727~
~TRUE~
~FALSE~
~Write Registry~
~{947D4AAA-5BE7-495C-9442-D1D1E9853E0A}~
~0~
~0~
~ThreadingModel~
~Both~
~TRUE~
~FALSE~
~Write Registry~
~{BAFBF634-CFEA-413E-B27D-100ED3571BB0}~
~0~
~0~
~CLSID\{C7678EE5-AA96-38DD-918A-970F1F7B469B}\InprocServer32\1.0.0.0~
~Assembly~
~TRUE~
~FALSE~
~Write Registry~
~{C170B158-6BC2-4EE1-8952-917956EE030E}~
~0~
~0~
~Class~
~TRUE~
~FALSE~
~Write Registry~
~{5F076682-7DE9-45BA-A534-8A2131E1E064}~
~0~
~0~
~RuntimeVersion~
~v2.0.50727~
~TRUE~
~FALSE~
~Write Registry~
~{4D1BC8DE-1BC2-49CF-B6D5-1B429B9323A1}~
~0~
~0~
~CLSID\{C7678EE5-AA96-38DD-918A-970F1F7B469B}\ProgId~
~TRUE~
~FALSE~
~Write Registry~
~{3D9D354D-79C8-4E15-8AB6-AAEAFCFA688F}~
~0~
~0~
~Interface\{435BD20C-73B6-419F-9E16-AAA7974D562C}~
~_IRapidSketchIntegrationEvents~
~TRUE~
~FALSE~
~Write Registry~
~{1E9B56B0-8DDF-43CD-9297-505ECF17A71C}~
~0~
~0~
~Interface\{49878903-D0E8-4B98-BC61-0F1CCC7757D5}~
~GdViewerCnt~
~TRUE~
~FALSE~
~Write Registry~
~{EC1FE267-62C1-499C-AB8B-90B90FD6E4C7}~
~0~
~0~
~Interface\{49878903-D0E8-4B98-BC61-0F1CCC7757D5}\ProxyStubClsid~
~{00020424-0000-0000-C000-000000000046}~
~TRUE~
~FALSE~
~Write Registry~
~{6B2311B4-1895-4462-A360-E2E0CF630C0B}~
~0~
~0~
~Interface\{49878903-D0E8-4B98-BC61-0F1CCC7757D5}\ProxyStubClsid32~
~TRUE~
~FALSE~
~Write Registry~
~{0DE46943-EAC9-4740-A291-3F5BF3A3FFCE}~
~0~
~0~
~Interface\{49878903-D0E8-4B98-BC61-0F1CCC7757D5}\TypeLib~
~{C30AFC8D-43BC-4B49-AA3B-775BDEDB9EB0}~
~TRUE~
~FALSE~
~Write Registry~
~{895AFFAE-4768-4D5E-8BE9-49E63612E9E2}~
~0~
~0~
~Version~
~1.b~
~TRUE~
~FALSE~
~Write Registry~
~{2549D877-9C65-4966-B056-180588010D27}~
~0~
~0~
~Interface\{4C092211-F870-4DB2-A3E7-9BE2DA2EF315}~
~GdViewer~
~TRUE~
~FALSE~
~Write Registry~
~{DCD86B57-2FAF-4E96-9536-2DD3403A6876}~
~0~
~0~
~Interface\{4C092211-F870-4DB2-A3E7-9BE2DA2EF315}\ProxyStubClsid~
~TRUE~
~FALSE~
~Write Registry~
~{003B7470-C25C-4D81-B541-908293F81DA5}~
~0~
~0~
~Interface\{4C092211-F870-4DB2-A3E7-9BE2DA2EF315}\ProxyStubClsid32~
~TRUE~
~FALSE~
~Write Registry~
~{ECE17849-41E6-49FD-8893-8B3F6047C9A3}~
~0~
~0~
~Interface\{4C092211-F870-4DB2-A3E7-9BE2DA2EF315}\TypeLib~
~TRUE~
~FALSE~
~Write Registry~
~{83762043-D693-48A7-B4F7-57E4E078E9B0}~
~0~
~0~
~Version~
~1.b~
~TRUE~
~FALSE~
~Write Registry~
~{384BAA86-CEFC-494B-8CF3-53A9132679F4}~
~0~
~0~
~Interface\{53AC816A-6292-4803-BDB7-336DD630D797}~
~cImaging~
~TRUE~
~FALSE~
~Write Registry~
~{9CCB24BA-50EA-4C7E-9FD5-1E6962A68C1F}~
~0~
~0~
~Interface\{53AC816A-6292-4803-BDB7-336DD630D797}\ProxyStubClsid~
~TRUE~
~FALSE~
~Write Registry~
~{9DB08FED-8C47-4214-AF43-70F5AB4B7023}~
~0~
~0~
~Interface\{53AC816A-6292-4803-BDB7-336DD630D797}\ProxyStubClsid32~
~TRUE~
~FALSE~
~Write Registry~
~{4A0A3031-C118-497A-97E5-34A96D016EB3}~
~0~
~0~
~Interface\{53AC816A-6292-4803-BDB7-336DD630D797}\TypeLib~
~TRUE~
~FALSE~
~Write Registry~
~{9C573171-1DD4-435E-BA30-1A50ABB0C7BF}~
~0~
~0~
~Version~
~1.b~
~TRUE~
~FALSE~
~Write Registry~
~{081F273C-23AA-46FE-82BD-4E2A12EBD6AA}~
~0~
~0~
~Interface\{540DF7CC-3BE7-4F0C-9753-8665DA0F69FE}~
~Imaging~
~TRUE~
~FALSE~
~Write Registry~
~{421FE595-D098-4890-BFBA-2389DEC76A45}~
~0~
~0~
~Interface\{540DF7CC-3BE7-4F0C-9753-8665DA0F69FE}\ProxyStubClsid~
~{00020420-0000-0000-C000-000000000046}~
~TRUE~
~FALSE~
~Write Registry~
~{44F407FB-B685-4AD1-81C1-D4513986C696}~
~0~
~0~
~Interface\{540DF7CC-3BE7-4F0C-9753-8665DA0F69FE}\ProxyStubClsid32~
~TRUE~
~FALSE~
~Write Registry~
~{708E3D06-1F61-4F1B-AD3D-B3021E49AB70}~
~0~
~0~
~Interface\{540DF7CC-3BE7-4F0C-9753-8665DA0F69FE}\TypeLib~
~TRUE~
~FALSE~
~Write Registry~
~{EC078616-729E-4486-A590-2F40522B5D2D}~
~0~
~0~
~Version~
~1.b~
~TRUE~
~FALSE~
~Write Registry~
~{7248F44E-C4F1-4818-A02B-709AD9A952C2}~
~0~
~0~
~Interface\{5ED1299E-7B17-4E97-ABE8-A838C125D961}~
~GdViewerCnt~
~TRUE~
~FALSE~
~Write Registry~
~{E20BAFAB-2136-4294-A9BA-BC609A8971B1}~
~0~
~0~
~Interface\{5ED1299E-7B17-4E97-ABE8-A838C125D961}\ProxyStubClsid~
~TRUE~
~FALSE~
~Write Registry~
~{B69CE2CE-1674-49EB-9D82-95E35808CC4B}~
~0~
~0~
~Interface\{5ED1299E-7B17-4E97-ABE8-A838C125D961}\ProxyStubClsid32~
~TRUE~
~FALSE~
~Write Registry~
~{71C8B531-9855-4EBC-A74E-8826A1294E30}~
~0~
~0~
~Interface\{5ED1299E-7B17-4E97-ABE8-A838C125D961}\TypeLib~
~TRUE~
~FALSE~
~Write Registry~
~{AA0D62C4-F98E-46B4-B0E6-4C18A50A3435}~
~0~
~0~
~Version~
~1.b~
~TRUE~
~FALSE~
~Write Registry~
~{C019CD9E-4B48-432E-859D-64DCA2E56D08}~
~0~
~0~
~Interface\{6BEFA146-BF3E-470F-AE56-01D8B9DE780C}~
~dummy~
~TRUE~
~FALSE~
~Write Registry~
~{3053336C-94EC-4DE6-B548-81A895B8E48B}~
~0~
~0~
~Interface\{6BEFA146-BF3E-470F-AE56-01D8B9DE780C}\ProxyStubClsid~
~TRUE~
~FALSE~
~Write Registry~
~{301730F8-E817-484C-B8FC-7C64FE1615F8}~
~0~
~0~
~Interface\{6BEFA146-BF3E-470F-AE56-01D8B9DE780C}\ProxyStubClsid32~
~TRUE~
~FALSE~
~Write Registry~
~{73F2B47E-9743-4846-AD15-3DCC17C82BB4}~
~0~
~0~
~Interface\{6BEFA146-BF3E-470F-AE56-01D8B9DE780C}\TypeLib~
~TRUE~
~FALSE~
~Write Registry~
~{FD00E862-0C3E-4748-82C7-9B34A363984B}~
~0~
~0~
~Version~
~1.b~
~TRUE~
~FALSE~
~Write Registry~
~{DEF9B049-86B6-41A1-AD20-A1B2389B372C}~
~0~
~0~
~Interface\{70A5C4BC-20EE-4F4E-A8E2-3B5CA37E8090}~
~RapidSketch~
~TRUE~
~FALSE~
~Write Registry~
~{E5F27662-E649-4A47-834A-D5A90599406A}~
~0~
~0~
~Interface\{866D602F-3F9C-4123-958A-802F3B6E7687}~
~IRapidSketchIntegration~
~TRUE~
~FALSE~
~Write Registry~
~{7DF9516B-CF66-45B7-B0D1-23136090407D}~
~0~
~0~
~Interface\{8A28B571-63F2-4883-A2E6-EFD9F8D9BEF1}~
~Imaging~
~TRUE~
~FALSE~
~Write Registry~
~{F895B8B9-8020-4441-8588-003961F7310E}~
~0~
~0~
~Interface\{8A28B571-63F2-4883-A2E6-EFD9F8D9BEF1}\ProxyStubClsid~
~TRUE~
~FALSE~
~Write Registry~
~{4771BBF0-FC37-44FF-BC4B-B9D81112436F}~
~0~
~0~
~Interface\{8A28B571-63F2-4883-A2E6-EFD9F8D9BEF1}\ProxyStubClsid32~
~TRUE~
~FALSE~
~Write Registry~
~{D40DC5B5-22F7-46C4-B76A-1B36317D41B1}~
~0~
~0~
~Interface\{8A28B571-63F2-4883-A2E6-EFD9F8D9BEF1}\TypeLib~
~TRUE~
~FALSE~
~Write Registry~
~{4A370B89-6283-4788-BE84-5426BD0E9339}~
~0~
~0~
~Version~
~1.b~
~TRUE~
~FALSE~
~Write Registry~
~{06F7527F-28ED-482D-A555-25337B9AEA57}~
~0~
~0~
~Interface\{A5899D00-5C62-46BC-8841-4CA9A8281355}~
~IArea~
~TRUE~
~FALSE~
~Write Registry~
~{D1B501C5-2EF3-484D-85C6-0815FD1FD86E}~
~0~
~0~
~Interface\{D78EB757-0B81-405B-BE1C-9951A47D557E}~
~ISketch~
~TRUE~
~FALSE~
~Write Registry~
~{635A4452-925D-4CCA-8E9C-2754ABDCF3E7}~
~0~
~0~
~Interface\{E323A7AD-29F2-4FF5-8DDC-30F567B87E46}~
~GdViewer~
~TRUE~
~FALSE~
~Write Registry~
~{F8F0D5E0-C837-48D2-B05F-7F3AFF91A116}~
~0~
~0~
~Interface\{E323A7AD-29F2-4FF5-8DDC-30F567B87E46}\ProxyStubClsid~
~TRUE~
~FALSE~
~Write Registry~
~{F52A6BA8-3EBC-40B6-8FFF-606A09DCE347}~
~0~
~0~
~Interface\{E323A7AD-29F2-4FF5-8DDC-30F567B87E46}\ProxyStubClsid32~
~TRUE~
~FALSE~
~Write Registry~
~{33EAA5B9-C687-467D-94EC-B0A4F89AF42D}~
~0~
~0~
~Interface\{E323A7AD-29F2-4FF5-8DDC-30F567B87E46}\TypeLib~
~TRUE~
~FALSE~
~Write Registry~
~{A5C9AB55-7DF9-408E-93F7-1171A08F0EF9}~
~0~
~0~
~Version~
~1.b~
~TRUE~
~FALSE~
~Write Registry~
~{66854C4D-B1FA-4621-B459-BADA4CDEB16E}~
~0~
~0~
~Interface\{E415D419-67E5-4AC8-97B2-FD79D4F1A517}~
~RapidSketch~
~TRUE~
~FALSE~
~Write Registry~
~{0575FA77-FDA1-42A8-B432-679559EC60D5}~
~0~
~0~
~MIME\Database\Content Type\text/AWOrder~
~Extension~
~.awao~
~TRUE~
~FALSE~
~Write Registry~
~{B0B8614D-006F-4E35-BDD4-20B81F3604B4}~
~0~
~0~
~$PROGRAMFILES$\Bradford\ClickFORMS\Tools\Orders\OrderProcessor.exe%1~
~TRUE~
~FALSE~
~Write Registry~
~{86919206-CFA0-4E94-9140-5EFA9163977B}~
~0~
~0~
~OrderProcessor.Application\shell\open\command~
~TRUE~
~FALSE~
~Write Registry~
~{41634C5E-4B3C-41B4-AC28-939D46FBB2E8}~
~0~
~0~
~OrderProcessor.Document~
~OrderProcessor Document~
~TRUE~
~FALSE~
~Write Registry~
~{54E766AF-4FF7-4D02-B1BA-827DE770BCC8}~
~0~
~0~
~OrderProcessor.Document\DefaultIcon~
~$WINDIR$\Installer\{2FE47056-6D13-4843-9143-65754A58DEF7}\Icon2FE47056.exe,2~
~TRUE~
~FALSE~
~Write Registry~
~{8F4DFD20-F604-43AD-A3C7-779FA7B23E1E}~
~0~
~0~
~OrderProcessor.Document\shell~
~open~
~TRUE~
~FALSE~
~Write Registry~
~{FAD5716B-98DE-42B7-BE63-508792E8818D}~
~0~
~0~
~OrderProcessor.Document\shell\open~
~open~
~TRUE~
~FALSE~
~Write Registry~
~{A46570BF-DCC0-41A0-9451-0BB95DF42CEE}~
~0~
~0~
~OrderProcessor.Document\shell\open\command~
~TRUE~
~FALSE~
~Write Registry~
~{05487AE6-AF5E-4436-B1CD-62B6B2918512}~
~0~
~0~
~command~
~X*GI30817?(y,gML$RAX>@BY(YU%O4AXZ80S?OBJ7 "%1"~
~FALSE~
~APPEND~
~Write Registry~
~{68012427-3D8E-4305-BA43-FDECEADD3B68}~
~0~
~0~
~command~
~FALSE~
~APPEND~
~Write Registry~
~{BC715EA3-2E63-43F0-BDC5-2E18AE5A524B}~
~0~
~0~
~command~
~pen~
~FALSE~
~APPEND~
~Write Registry~
~{2377DA7F-3F48-4321-BD1A-A14C51746D00}~
~0~
~0~
~TRUE~
~FALSE~
~Write Registry~
~{FA9DBAC4-3BAD-4A4C-908F-922436273FCD}~
~0~
~0~
~TRUE~
~FALSE~
~Write Registry~
~{03CF759C-9DB6-499E-BBDE-515A3FEBE726}~
~0~
~0~
~Service.Mapping.Bradford.ClickFORMS.SplashForm\CLSID~
~{C7678EE5-AA96-38DD-918A-970F1F7B469B}~
~TRUE~
~FALSE~
~Write Registry~
~{4272E2E5-69D5-4ABF-864D-BC09A15CD013}~
~0~
~0~
~Service.Mapping.Bradford.ClickFORMS\CLSID~
~{33CC5481-1B8E-49CF-A109-BD3B414ED540}~
~TRUE~
~FALSE~
kpm30519
Post by kpm30519 »
Thanks Francisco!
:D
