I'm using the latest version of IA and am in Product Details, Programs, Direct Deploy.
I'm trying to load an Icon but the system says: Invalid Icon File, please choose another Icon...
The file is a perfectly good icon file with extension .ico.
What could be going wrong? Help says: You may use icons of any color depth and resolution.
Thanks and regards
Programs, Direct Deploy - Load Icon Doesn't work
Re: Programs, Direct Deploy - Load Icon Doesn't work
Dear Seán,
as reference, you can have a look at any icon file present within the InstallAware installation folder.
