I have searched and searched but cannot seem to find an answer to this one.
A little bit of backstory:
I am attempting to first unzip an existing container, add files to the folder in which I extracted to and modify certain config files, delete the old container, and create a new zip container with all of the files mentioned.
Everything except for the creation of the new zip container is working fine. I am able to extract, modify and then delete the original container without problems.
I have been attempting to use Compress 7Zip Archive within Installaware but cannot seem to get it right. I am not receiving any errors and the program does not seem to be able to even create an empty container.
I believe I am doing something wrong but cannot determine what since I have no direction as to what is happening. Any direction would be appreciated. (some example scripts within the F1 menu would be helpful
I am an open book so please, if it helps you understand my issue, ask away.
