priviledges problem on 64 bit systems
npf
Postby npf » Thu Nov 14, 2013 4:17 am
InstallAware Version 18
Build of the Setup Routine on Win 7 32 bit
Application requirements: Administrator priviledges YES / 64 bit operation system NO
The .ocx und .ttf files are installed by "Setup Architecture and files"
There are Problems running the Setup on 64bit Workstations (Windows-Server Systems)
The installation failed with regsvr32 und fonts
I am quite sure there are problems with the user priviledges.
Can you imagine what can be the problem?
Run Program regsvr32 /s $WINSYSDIR$\mscomct2.ocx (WAIT)
Run Program regsvr32 /s $WINSYSDIR$\vsflex8.ocx (WAIT)
Run Program regsvr32 /s $WINSYSDIR$\vsflex8l.ocx (WAIT)
Install Fonts from '$PROGRAMFILES$\npf\Fonts\*.ttf' (remove empty source directory after installation)
~InstallAware Clipboard Data~
~Install Fonts~
~{FC5A9484-3AEE-4050-AA75-9D4EF9BA8817}~
~V211$PROGRAMFILES$\npf\Fonts\*.ttf~
~Install Fonts IDE-PlugIn.dll\Install Fonts EXE-PlugIn.dll~
~Run Program~
~{ED5848F7-1581-4280-9787-DA16008E231F}~
~regsvr32~
~FALSE~
~/s $WINSYSDIR$\vsflex8l.ocx~
~TRUE~
~Run Program~
~{199CC5B0-0DFE-4985-BD68-06B6E45A7701}~
~regsvr32~
~FALSE~
~/s $WINSYSDIR$\vsflex8.ocx~
~TRUE~
~Run Program~
~{CCF8DE96-CFA0-4FD7-B637-C0396D18FB30}~
~regsvr32~
~FALSE~
~/s $WINSYSDIR$\mscomct2.ocx~
~TRUE~
~Apply Changes~
~{700B9266-934D-4EE5-9DFF-4F165C5446BF}~
~progress~
~SUCCESS~
~TRUE~
~FALSE~
Re: priviledges problem on 64 bit systems
Postby FrancescoT » Fri Nov 15, 2013 12:35 pm
without having your file it is not easy to find out what really is the cause the failure.
have you tried to manually execute "regsvr32" (via CMD prompt) with those files?
does it work?
npf
Postby npf » Fri Nov 15, 2013 1:00 pm
Dear Francesco,
yes, manually it works on all systems. And IA works without problems on stand alone machines, peer-to-peer Systems and on my own vitual machines.
Mostly it fails on bigger server systems.
What can I send you in which way?
Regards Norbert
Postby FrancescoT » Fri Nov 15, 2013 1:13 pm
Dear Norbert,
it is enough a very very minimal project* that replicates the issue.
*Include at least a file to test the "regsvr32" execution with the project.
If you prefer, you can send it to; support@installaware.com
npf
Postby npf » Fri Nov 15, 2013 3:53 pm
Dear Francesco,
I have sent the project to support@installaware.com.
I have commented ou everything not necessary.
Regards Norbert
Postby FrancescoT » Mon Nov 18, 2013 10:49 am
Dear Norbert,
Received!
npf
Postby npf » Wed Jan 15, 2014 3:01 am
Dear Francesco,
could you localize the problem?
Regards, Norbert
Postby FrancescoT » Wed Jan 15, 2014 12:06 pm
Dear Norbert,
I am very sorry ... I totally missed to work on your files.
I'll be back soon.
Sorry!
Postby FrancescoT » Thu Jan 16, 2014 11:06 am
Dear Norbert,
please check your email.
I just sent a message to you.
Users browsing this forum: pfennig and 88 guests
