CreateUser fails - how to rollback?
Sheri_Steeves
Postby Sheri_Steeves » Wed Nov 20, 2013 8:52 am
As part of my install I need to create a new local administrative user. This I have in place and after ApplyInstall is called, the call the CreateUser is made.
The problem is this -> if this call fails, i.e. the user cannot be created, I need to rollback the install.
This account must exist, and several services must be installed under this account for the product to work correctly.
Basically if I cannot create this account then I need to either a) terminate and rollback, or b) do this check during the dialog part of the install.
Can I call CreateUser before the ApplyInstall - preferably during the dialog process so I can prompt the user?
What is the best way to approach this?
Sheri
Re: CreateUser fails - how to rollback?
Postby FrancescoT » Wed Nov 20, 2013 11:29 am
Dear Sheri,
... I suggest you to use the "Create User" command before the effective package installation (... during setup interview).
It is not a Windows Installer command, so you can definitely use it before the Apply Install statement.
Sheri_Steeves
Postby Sheri_Steeves » Wed Nov 20, 2013 11:51 am
Francesco,
Perfect.... that's what I'll do then.
Thanks for the quick response.
Sheri
Postby FrancescoT » Thu Nov 21, 2013 11:30 am
:D
Users browsing this forum: No registered users and 81 guests
