Does HTMLVIEWER support iFrame or object tags?
hdwivedi23
Post by hdwivedi23 »
there are many tags that HTMLviewer does not support. For instance iFrame is not supported. I am using iFrame to embed a html page within another html page. Even object tag is not working.
These pages work on a browser but not on the installer.
Is there a way to make it work?
Also, can you give me a list of all the tags that are supported by HTMLViewer.
Re: Does HTMLVIEWER support iFrame or object tags?
Let me verify if I am able to find out a possible list of supported tags ... anyway, I suppose these are limited.
hdwivedi23
FrancescoT wrote:Dear User,
So, did you find out the list of tags compatible with HTMLViewer?
I have been informed that the control should support most of the HTML 3.2 specifications.
Unfortunately, it is not available a detailed list of supported tags and but I can confirm that iFrame is not supported.
