IA 18: BackGround Color CheckBox
mikKummerfeld
Post by mikKummerfeld »
Hey Guys,
10 minutes of IA 18 and I found the first bug. The Color of CheckBoxes (Background) and labels and text in buttons does not work anymore.
What the hell is going on? :( :( :(
Heiko
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: IA 18: BackGround Color CheckBox
... how did you check it?
mikKummerfeld
All Color-Properties of a Checkbox is set to clRed, and in IA 15 it was red in Dialog designer and runtime and Setup. And now it is White.
In all of my Projects :( Screenshot and DFM-Files attached
hauptdialog.dfm.zip
(229.74 KiB) Downloaded 497 times
Kind regards
Heiko Kummerfeld
MIK GmbH
Dear Heiko,
I wìll send a note about this behavior to our dev team.
SteveDude
Post by SteveDude »
You can send this one to them as well. Dialog background color is not recognized on XP. Works fine on all other OS's and is a only noticeable at runtime.
NOTE: This is a legacy bug that has been around for several versions.
...let me check!
