Hey Guys,
is there a new documentation for the new object properties of the dialog designer? I cant find any documentation about this, even in interop directory.
The ImageIndex-Options, Touch and Gesture-Options and so on. There are a lot of properties with no options in it (empty dropdown) and I dont know how to use them.
IA 18: Documentation Dialog Designer
mikKummerfeld
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Heiko Kummerfeld
MIK GmbH
mikKummerfeld
Re: IA 18: Documentation Dialog Designer
Any Information ?
Kind regards
Heiko Kummerfeld
MIK GmbH
Heiko Kummerfeld
MIK GmbH
Not yet!
As soon I receive an answer I'll post it back.
I am reviving this old post, because I too recently ran into this issue. The documentation on the advanced features of the Dialog Designer is slim to none.
Great example is the "Select Custom Folder" Object Interaction Action. I eventually found documentation for how it works in the "What's New" article under the InstallAware 12 section, but even that isn't very helpful. This kind of common dialog customization, having a second file location selector, should have an article with examples in the built-in or online help.
Some additional samples are available with the following link.
http://www.installaware.com/forum/viewt ... f=2&t=6772
If I recall correctly, I should have released some time ago a sample that demonstrates how to handle a second file location selector.
Let me check this.
Let me check this.
