Possible to show downloaded picture?
mikKummerfeld
Postby mikKummerfeld » Wed Dec 18, 2013 1:21 am
Hey Guys,
is it possible to download a Picture before showing a Dialog and then showing this Picture inside the Dialog? I want to Show our current Software RoadMap to the customers
and we Change the Roadmap sometimes. Would be great to update that on the Server and every customer has the new Roadmap automatically.
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: Possible to show downloaded picture?
Postby FrancescoT » Wed Dec 18, 2013 12:10 pm
Dear Heiko,
I suppose it could be done as follow;
"Define a script variable that has the same name as the target TImage control on your dialog. Before showing the dialog, set this variable to the full file system path of the image that you wish loaded onto the control (such as a file in $SUPPORTDIR$, or a file installed/already present on the target system). If the variable is not defined in the script or does not contain the full path of a file that exists, the existing image will be used and no new image will be loaded."
mikKummerfeld
Postby mikKummerfeld » Thu Dec 19, 2013 2:17 am
IT WORKS LIKE A CHARM, THANK YOU :)
Kind regards
Heiko Kummerfeld
MIK GmbH
Postby FrancescoT » Thu Dec 19, 2013 12:43 pm
:D
Users browsing this forum: No registered users and 134 guests
