Hey Guys,
the following bug appears in IA 18, and it was OK in IA15.
Create a pagecontrol-object with e.g a few tabs. Put different content in every tab and close/save dialog designer with the first tab activated (and the content for the first tab).
Then open the dialog again in designer and you see the first tab activated with the content of the last tab !
Heiko
IA: Bug in PageControl-Object
mikKummerfeld
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Heiko Kummerfeld
MIK GmbH
Re: IA: Bug in PageControl-Object
Yes, it seems true what you are reporting.
... anyway, I found that happens only the first time and then page-control refreshes correctly after a successive tab selection.
In addition it works fine at runtime and it seems to happen with using the dialog editor only.
