After updating from IA 15 to IA 18 installer will no longer work.
During the installation it will say "Systen cannot find the file specified"
The installation is done via command line
miabuild.exe "Zebra Designer Pro.mpr" /b=2 /r VERSION=%LDA_VERSION_NUMBER%
and has always produced only one file.
The switch /b=2 is supposed to create a "2: Compressed Web-Based EXE"
and in the Web Media Blocks section is no other file reported.
attached is the project file renamed to txt.
I also can't go back to version 15 of IA as the installer doesn't work properly either.
Best regards,
Installer can't file during installation
- Zebra Designer Pro.txt
- (6.46 KiB) Downloaded 456 times
Manfred Wilner
Re: Installer can't file during installation
I think I got it working again.
I went back to a working install and loaded everything into a clean folder and it started to work again.
Manfred Wilner
More on this if anyone may have the same issue.
After the update I had to run the installation in the UI first and then it would work in the automated setting with miabuild and command line switches.
Also at this time there was no reference in the Web Media Blocks section to any other file.
Manfred Wilner
