Command line for logging
deestuar
Postby deestuar » Fri Dec 20, 2013 7:22 am
I have just inherited this product in my new role and really require to do something simple but unsure how.
Basically I want command line parameters so I can silent install the product /s or log to some text file
/l=mytextfile.com so I can find any installation issues juts by reading the log. Simples really :)
I know nothing about installaware I'm a Newby but appreciate any guidance/help etc
Stu
Re: Command line for logging
Postby FrancescoT » Fri Dec 20, 2013 11:42 am
Dear Stu,
that is simple!
To test this functionaly on the fly, create a new project from scratch using the Basic template and then build the project as Compressed exe.
Then run the package as follow (silent mode + log file);
<setup.exe> /s /l=<logfile.ext>
where;
<setup.exe> = full path to your setup exe file
<logfile.ext>= full path to your log file ("c:\mylog.txt")
Hope this helps you
Return to “Sample Scripts”
Users browsing this forum: No registered users and 1 guest
