Task manager shows it as 32 bit installation process
rahul
Post by rahul »
hello support,
i created 64 bit installer.
While installing 64 bit installer build , windows task manager shows it as 32 bit installation process.
how to it resolve this issue my build is 64 bit but task manager show 32 bit process...
Re: Task manager shows it as 32 bit installation process
Dear Rahul,
of course your package is a 32 bit apllication ... you should monitor the Windows Installer Engine process instead!
