change icon on update window
rahul
Post by rahul »
hello support,
I want to change icon on my update window.
i marked icon in red circle
icon of check for updates.jpg (33.2 KiB) Viewed 3648 times
how could i do this? please provide me solution
Re: change icon on update window
Dear Rahul,
by default, the update process is embedded with the setup package and that icon, is the one you have defined with your package project.
If you want to have a different icon with the update process, you need to modify the default update process with creating a specific project for this purpose.
