Backslash woes writing to registry
MarkThorogood
Postby MarkThorogood » Fri Jan 17, 2014 7:39 am
I have Installaware 2012 Admin edition I'm trying to write the following:
Provider=Microsoft.Jet.OLEDB.4.0;User ID="";Data Source=\\server1\vol3$\databases\mbs\new_mbs\mdb.mdb;Persist Security Info=False;Jet OLEDB:Database Password="xxxxxxx"
as a string registry data value.
The problem is Installaware is converting the double backslash to a single so is writing:
Provider=Microsoft.Jet.OLEDB.4.0;User ID="";Data Source=\server1\vol3$\databases\mbs\new_mbs\mdb.mdb;Persist Security Info=False;Jet OLEDB:Database Password="xxxxxxx"
I've tried all sorts of things, it has something to do with the dollar symbol. The only way I could get it to function was use "\\\\\\" instead of "\\" but that seems a hack. I have successfully written other registry value where a double backslash is present.
Is there anyway to escape the dollar sign (I've even tried using a variable $DOLLAR$ to represent a $ but that still fails)
Any suggestions please.
Re: Backslash woes writing to registry
Postby FrancescoT » Fri Jan 17, 2014 12:51 pm
honestly, I just tried the following code ... and it works fine.
Write Registry Key HKCU\Software\myproduct\Test, \\server\mypath
Set Variable MYVALUE to \\server\mypath
Write Registry Key HKCU\Software\myproductTwo\Test, $MYVALUE$
~InstallAware Clipboard Data~
~Write Registry~
~{18EE2682-E961-47CB-B7EE-0D14837BFB00}~
~0~
~1|~
~Software\myproductTwo~
~Test~
~$MYVALUE$~
~TRUE~
~FALSE~
~Set Variable~
~{C949172B-CDD2-4496-B127-67A1958B35B1}~
~MYVALUE$MYAH$MYAH$FALSE~
~\\server\mypath~
~Write Registry~
~{DCB62CAE-3B31-4FF6-B63A-3C0270449E65}~
~0~
~1|~
~Software\myproduct~
~Test~
~\\server\mypath~
~TRUE~
~FALSE~
MarkThorogood
Postby MarkThorogood » Sat Jan 18, 2014 3:51 am
Thanks for trying and the reply, but your example doesn't use the data that I mentioned caused a problem, also I have a further issue that I set registry entry as permanent and when I did a installer repair the registry items disappeared. So given up on installaware for this functionality and as I find increasing the case with software I'm doing it myself using a dll.
Postby FrancescoT » Mon Jan 20, 2014 5:13 am
Dear Mark,
I am not able to replicate the same ... if you post a minimal sample project I'll verify it.
Users browsing this forum: No registered users and 140 guests
