"2|" is not a valid integer value
glenharvy
Post by glenharvy »
I'm using IA 18 and get the above error when I select the Registry option under Setup Architecture.
I have commented out any MSI code that reports it has found "2|" but this make no difference.
How can I fix this so I can access the Registry settings.
glenharvy
Re: "2|" is not a valid integer value
Post by glenharvy »
Downloaded and installed 18.4 which seems to have fixed this issue.
:D
