Silent install not working for MSI
tzachk
Post by tzachk »
Hello support,
I have a problem installing our msi in silent mode. It used to work in the past, but it is not working anymore.
I've tried to install the setup.exe in silent mode. Working great. Tried to install setup.msi, it starts (as evident in task manager), consumes 99% cpu and stays at that setting. The installation itself is not progressing.
Logged the msi install process, everything is fine.
What can go wrong?
Regards,
T.
Re: Silent install not working for MSI
Dear TZach,
did you rebuild it or is it the same identical MSI file that you used before?
tzachk
Post by tzachk »
Dear Francesco,
It is a new MSI.
Every new msi I build hangs on silent mode. Working fine if exe is run in silent.
Tzach
tzachk
Post by tzachk »
Hi Francesco,
I'm trying to produce a log file but fail.
Is the following correct?
Setup.msi /quiet CMD="/s /l=c:\log.log"
Regards,
T.
tzachk
Post by tzachk »
Hi Francesco,
I was able to produce a log file by running the setup.exe with the command parameters I saw in task manager.
The command line is:
Setup.exe /s /l=c:\log.log "/g=c:\" ALLUSERS=FALSE /m="C:\Users\Administrator\AppData\Local\Temp\{F47FDBD4-EE5E-4A24-8741-42CC9C171325}.exe" /k=""
The resulting log file is attached.
By the way, I noticed that eventhough I set in the installer script Set Persistent Variable ALLUSERS to TRUE the exe is run with ALLUSERS=FALSE.
Your help is needed.
Regards,
T.
log.log
(282.13 KiB) Downloaded 1049 times
Dear Tzachk,
Try with;
msiexec.exe /i <msi_package> CMDLINE="ALLUSERS=TRUE" /quiet
Alternatively, use the Group Policy Wizard tool to embed the "ALLUSERS" variable value with MSI file.
tzachk
Post by tzachk »
Hi Francesco,
If I add ALLUSERS=TRUE as you've mentioned. then the resuling executing line includes both ALLUSERS=FALSE and ALLUSERS=TRUE.
Is there something I can do or is this part of the gp wizard?
Regards,
Tzach
Dear Tzachk,
but ... does it work?
The gp wizard gives you the possibility to embed the command line parameter with the MSI ... it is exactly the same with passing them manually.
tzachk
Post by tzachk »
Hi Francesco,
To understand if it works we need to look at the registry and/or try to uninstall with another user.
I hope these test (if pass) means that ALLUSERS=TRUE works.
I still do not understand why ALLUSERS=FALSE appear in the command line when i set it to true in the installaware script.
Regards,
Tzach
Dear Tzach,
I am sure that works!
