I am using the default direct deploy script.
1. Should the Run Remote Program command WAIT for finish to return a result? It is not doing this in my environment.
2. How can the Temporary admin share/folder be deleted and cleaned up after installation on a remote system?
Direct Deploy
Direct Deploy
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
Re: Direct Deploy
Dear Jim,
1- The command doesn't wait and for what I know, it should not return any value on success.
2- You should not delete that folder, unless your package is not anymore installed on any computer in your Domain.
Otherwise you will need to reinstall it once again from your domain server, in order to be able to remove it from your Domain server.
Anyway, if you want to delete that folder you should implement the following code (supposing you are using the default DirectDeploy script ... not customized):
the same as InstallAware clipboard format;
Recursively Delete Files \\$DDCOMPUTER$\admin$\$REVISIONCODE$\*.*
Call DLL Function kernel32.dll->RemoveDirectoryW
~InstallAware Clipboard Data~
~Call DLL Function~
~{CF729CC1-46C1-47EB-9C8E-B586D1A7C132}~
~kernel32.dll,RemoveDirectoryW,bool,,"pointer to UNICODE string",\\$DDCOMPUTER$\admin$\$REVISIONCODE$,$~
~mIDEFunc.dll\mEXEFunc.dll~
~Delete Files Recursive~
~{386BD890-7D7D-4581-9F44-A87C56E405FF}~
~\\$DDCOMPUTER$\admin$\$REVISIONCODE$\*.*~
Users browsing this forum: Google [Bot] and 81 guests
