I set up the Authenticode options for the installer using the exact same certificate files I am using to manually sign
with. The manual process works fine, but when I use InstallAware, I get a very cryptic error simply stating that
"Code Signing Failed".
Here is a snapshot of the manual signtool file path -
Here is a snapshot of the Install Aware file path -
Here is a snapshot of the error -
I also verified my password multiple times and insured file permissions were correct. Also reviewed
the forums and FAQs regarding code signing issues.
Is there a way to further diagnose the error ?? I need this process to be automated and am unable
to get around this issue.
Thanks for any suggestions..
Todd
Error Signing Code - No Explanation
- File Path For InstallAware
- SigningError2.png (8.25 KiB) Viewed 4958 times
Re: Error Signing Code - No Explanation
Dear Todd,
For what I see by your screen-shots, I suppose that it is probably caused by the miss-spelled value enterd with the timestamp URL.
It should be;
- http://timestamp.verisign.com/scripts/timestamp.dll
instead of;
- http://timestamp.verisign.com/scripts/timstamp.dll
It should be;
instead of;
After going through my entire process again, I realized that InstallAware was running in a different OS. It appears
to boil down to a Windows Server 2003 failing and Windows 7 working. Not an InstallAware issue.
Thank you for your suggestions and assistance.
Todd
Todd
Happy you solved
