Is there any way to specify the language for the install by command line?
Is there any way to control whether the Language Selection Dialog box is displayed based on a command line specified language?
Language Selection
Sorry, not at this time.
The default language is auto-selected based on the system language.
The language dialog is turned on/off in the Project Options window.
Also, if you would like to set the language at runtime, use the LANGUAGE pre-defined variable. See the Multi-Lingual setups for an example that shows how to change the language at runtime in this way. You could hide the pre-built language dialog, and customize this project, to make your own language selection dialog with support for command line switches (stored in the CMDLINE variable).
