Patching for Uncompressed?
tofutim
Postby tofutim » Thu Jan 23, 2014 3:02 pm
Is patching only for Web deployments? Or is it also for Uncompressed? Seems that when patches are used against uncompressed, it gets confused and tries to find the original source.
Re: Patching for Uncompressed?
Postby FrancescoT » Fri Jan 24, 2014 12:01 pm
Dear Tofutim,
I believe you missed to set the "Always Cache Setup Sources (enables easy patching)" check control (Press SHIFT+CTRL+F11).
Please refer to the available documentation for more details.
tofutim
Postby tofutim » Mon Jan 27, 2014 10:07 am
Are you saying that I can patch both compressed (Web) and uncompressed with the same patch? Is the cache function on the user side or developer side?
Postby FrancescoT » Mon Jan 27, 2014 12:35 pm
Dear tofutim,
What do you mean with both compressed (Web) and uncompressed? are you referring to two distinct projects?
If it is the same project, sure you can.
Obviously, I am supposing that you are not patching files that could be conditionally installed via WEB MEDIA BLOCK.
It is an InstallAware project setting ... (... if I haven't missed your question).
