I have created an installer for a service which it works. But it does not start the service when the install completes.
I have noticed that nothing I build runs when installed either even though the tickbox to run the application is ticked.
Also when I uninstall the service there are still references to the service in the Services.msc. We only deploy in-house so these are minor issues but any help you can give would be appreciated.
Kind regards
Andrew
Service Installer
Andrew Brent
Service Installer
Andrew Brent
Designer Contracts Ltd
Visual Studio 2022 - DevExpress - InstallAware X15
Re: Service Installer
Dear Andrew,
how did you try to start it from your script?
