Hello
We need to check the Date Modified date of an EXE before we run our update or even allow the update to run.
Is there a date compare in IA where I an say IF (FileDate > mm-dd-yyyy) Then blah
AND
have it know date formatting so canada doesn't mess it up with dd-mm-yyyy?
Thanks!
File Date Check
Re: File Date Check
There is nothing built in to do this I'm afraid; you may be able to call one of the Windows internal functions to get something along the lines of what you are after (using the Call DLL Function).
Alternatively, you could check the file version instead.
Users browsing this forum: No registered users and 97 guests
