Predefined Language
rama1709
Predefined Language
Postby rama1709 » Wed Feb 26, 2014 4:11 am
I use the pre defined variable LANGUAGE to find out, if the selected installation language is German or not. Dependend of this information i want install a german or an english help file. The code i used is the following:
Set Variable INSTALLLANG to $LANGUAGE$
 if Variable INSTALLLANG Equals German
    Create Shortcut $SHORTCUTFOLDER$\Hilfe to $TARGETDIR$\system\help\deutsch\ems-edm.chm, Pin to Start Menu
 else
    Create Shortcut $SHORTCUTFOLDER$\Hilfe to $TARGETDIR$\system\help\english\ems-edm.chm, Pin to Start Menu
I watch the Variable INSTALLANG in debug mode and the value ist German but always the else part is executed. Where ist the mistake?
bokkie
Re: Predefined Language
Postby bokkie » Wed Feb 26, 2014 7:25 am
The help definition for the pre-defined language variable says:
LANGUAGE: Set to an empty string in non multi-lingual installs. In multi-lingual installs, holds the active language. Assign a new value to this variable to change the active language from within your setup script in multi-lingual installs.
Likely result is that the language value might be null. Consider displaying it's value in a message box before the 'if' statement. That will confirm if it has a language value.
Postby FrancescoT » Wed Feb 26, 2014 11:21 am
Dear rama1709,
What Peter posted it is correct!
If you want to conditionally create your shortcut based on target OS Language, you can use the "Get System Setting" command to assign your INSTALLLANG variable.
rama1709
Postby rama1709 » Wed Jun 25, 2014 8:50 am
The only problem was the was the spelling of German and GERMAN. I use the Statement in this way
  if Variable MyLANG Contains (Ignore Case) GERMAN
and it works.
Postby FrancescoT » Wed Jun 25, 2014 11:10 am
:D
Users browsing this forum: No registered users and 61 guests
